Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
Front power windows stoped working
Both front power windows stopped working at the same time . Is it a fuse, relay, or switch ?
And where is it located ?
front passenger side only, all other windows work
No, the power works going down but not up.the one side of the cable is not connected.
=== Update (12/25/2019) ===
One side of the tension cable is off, where does it go?
theretreat7 , Check F28 40 amp fuse engine compartment fuse/relay center. If fuse OK check for power at window switch(key on). If no power check for broken pinched wire harness between driver side door and door opening(dog leg) you will have to unwrap or remove boot covering harness. If has power to switch panel, test switches, switch test good, test window motors(may have individual circuit breakers on them), if switch test bad replace the switch panel assy. Use the links below to aid in diagnosing your power window issue. Good luck.
http://www.agcoauto.com/content/news/p2_...
https://www.youtube.com/watch?v=2tLmH05U...
http://www.aa1car.com/library/power_wind...
Most likely a fuse or relay. Check your owners manual for where it would be located. if its a fuse make sure its not broken. If its a relay try with a different relay if it still doesn't work your motors could have burned out although unlikely. Do the rear windows still work? If you don't have an owners manual there normally a fuse box under the steering wheel or under the hood normally near the drivers side.
I hope this helps and good luck fixing!
I have the same issue and my door locks and rear window wings work. We replaced the switch and it still doesn't work. It started with them intermittently working and then stopped completely.
Front driver side window fuse
Widows won't come down
Update (08/04/26)
Flora IN.46929
theretreat7 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 54
crwdns2959996:0crwdne2959996:0 24,583
