kenwhitlock1 , Check under hood for wire harness excessively wet or corroded around connections and fuse box. If all looks good, from a lot of forums I checked, it could be a problem with the (GEM) Generic Electronic Module. Locate the GEM (link #1) and check it for excess moisture/corrosion/connection also. Test can be ran by a good Technician to check circuits going to GEM to see if it is bad. Link #2 mentions a TSB on a like problem also.Good luck.
https://www.youtube.com/watch?v=RG6YVkZ1...
http://www.justanswer.com/ford/39bry-own...
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
