@houseofdavid , David , You may have to remove the gas tank if in the way, cable loops behind deck, then gets secured in a wire hanger or if missing, tie strap(use a couple) as you feed cable along, to inside frame rail/body above deck feeding it up to the control lever through slot/hole/opening. It is actually easier to hook cable up to the lever first and feed down from the top along frame rail attaching as you go with a few plastic tie straps as you go. Links below may help a bit. Good luck.
http://homeguides.sfgate.com/replace-clu...
https://www.youtube.com/watch?v=q6cKjePh...
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
3
