Coolant temp sensor P0117 code
My check engine light came on and code ran P0117 code which ia the coolant temp sensor. We changed thw sensor but My check engine light is still on... What else can i do?
@cboleman , Courtney Boleman , Did you have the code cleared after changing the sensor, if not the light could remain on until a certain amount of drive cycles have been done. If the code was cleared, you should have the vehicle scanned again to see if it is indeed the same code coming back or if it is different.
Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track.
Good luck.
We did have code reset. Light came back after 40 miles
@cboleman ,Courtney Boleman, is it the same code coming back.
Hi,
You have checked the coolant level, also that the coolant is being pumped through the system, thermostat opening etc? What does the temp gauge on the dash show?
Code P0117
Possible causes Low engine coolant level , Faulty Engine Coolant Temperature (ECT) sensor, Faulty engine coolant thermostat, Engine Coolant Temperature (ECT) sensor harness is open or shorted, Engine Coolant Temperature (ECT) sensor circuit poor electrical connection
Yes it is the same code again. Our dash borad 190
crwdns2942667:0crwdne2942667:0 2,120
