How do I fix my wheel bearing
my wheel makes a weard noise when im driving
crwdns2915118:0crwdne2915118:0
If the noise is coming from the front of the car and is more noticeable when turning its probably the CV joints which involves replacing a major part of the front suspension. If that's it and you do not feel qualified to do that kind of work and have the necessary tools I would leave it to a professional.
How do you take bearing house off the spindle. 2007 ford focus 2.0
Check your sway bar links. its a 22 dollar fix from autozone.
the sway bar links on these cars are known to bust.
To check the links, http://i96.photobucket.com/albums/l185/b....
should look about like what's circled in red.
you'll need to first jack you car up to unload the suspension.
take your wheel off and yank on the thing to no end, also examine the bushings, if they are shot(like mine were), it's probably a good idea to replace them. While jerking that thing around if you can re-create the noise you're hearing you'll know that you need to change them.
In the case of mine i couldn't tell until i put a wrench on one and tried torquing it, then it made the loud, signature *CLUNK* as if i was driving over a bump.
easy fix, 2 bolts on each side. bolts may be seized on. buy some PB blaster and blast the sh*t out of them.
make sure to re-torque them after 20 minutes of driving.
your focus should drive smooth as butter and be quiet as @&$$ :)
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 16,409
Are you referring to your steering wheel or to one of your front drive wheels?
crwdns2934271:0crwdnd2934271:0 rj713 crwdne2934271:0
