Hi Tammy, okay...I've seen the responses with all kinds of needless questions so I will make this really easy!
1/. Just plug in the HDMI plug you got from cable box to HDMI port to TV... Use the HDMI 1 port on TV please for this step. After you plugged in both sides of the HDMI to its proper places then plug in box electrical wire to get power! Before turning on cable box turn on the TV and use the remote to get to the setting of the TV where u can see which channel line u are needing to use to get reception feed which should be HDMI 1.
Now once this is done turn on cable box... and wait till it goes through its setup! It would also be a good thing to make sure that the cable wire is in the right place for me its the back center of my box but for u it can be on the far left because there are two places on the xfinity box u can screw the cable two which could be the simple problem... as the TV and Box are both on try screwing on to either and give a few seconds for each to see if you get picture it should eventually work try the far left plug first though! And good luck!
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
crwdns2944067:014crwdne2944067:0
What model is this TV? all you are connecting is the Xfinity box?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
Yes. We are supposed to get a new box today. We will see if it works. I do not have the model number with me right now.
crwdns2934271:0crwdnd2934271:0 Tammy Pyrdum crwdne2934271:0
How have you connected the TV to the box with the antenna cable, HDMI cable, scart cable or component?
Have you used the cycle throught the source button on the TV to see if it finds the box on any of these?
crwdns2934271:0crwdnd2934271:0 Claes crwdne2934271:0
We got the new box. Tried it with the antenna cable and HDMI cable. Neither worked.
We moved the TV into another room and it will hook up to the box just fine. But not in the den.
The cable in the DEN is run from the attic to basement and up through the floor (not a jack). On this cable line is a splitter in the basement which the other cable goes to the bedroom. The TV in the bedroom is working fine.
We see nothing wrong with the cable coming to the den. We have also hooked another TV up in the den to the new box ..it does not work either .
However, we can bring one of our old smaller boxes into the den and it works with the smaller TV but will not work with the new TV.
NOTE: Cable Antenna is not listed as a source on the new TV.
Hi, Is your smaller box or smaller TV capable of given you a signal level/ quality reading? Usually in TVs and boxes there is a menu item that allows you to check signal level and quality. It may be that the splitter is faulty and that the level or quality of the signal is too low for the new box or the TV.
Also what is the model number of the new box and the new TV?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
crwdns2934275:09crwdne2934275:0
