A stapler is a mechanical device that joins pages of paper or similar material by driving a thin metal staple through the sheets and folding the ends. Staplers are widely used in government, business, offices, work places, homes and schools.
Where does spring go?
where does spring go in manual stapler
Where can I buy a spring for a nematic staple gun thanks Mary
This doesn't work for swingline 444
Eric Fields , I assume you are asking about the long thin feed/load spring which usually connects to a small tab on the staplers upper slide housing and to a tab on the slide. The links below should help you out in seeing spring mounting locations. On the guide link once you have opened it you can zoom in on where the spring is attached. Good luck.
https://www.youtube.com/watch?v=4micBJTd...
Stapler Maintenance
crwdns2889612:0crwdne2889612:0 8
here we describe everything ..
https://dailytoolsguide.com/?s=how+to+fi...
Eric Fields crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 43,106
