Phone was washed LG L Bello
Phone was drained with rice and heater, but display is black and its touching.
hope for help! :)
hope for help! :)
@gytisifixit , Gytis T. , Do not try to power on the device and remove battery ASAP. I will post a few links below, 1st link will be a general guide explaining how to clean water damaged electronics and 2nd link will show how to disassemble your device so you can hopefully clean water/corrosion and get device working.
Gytis, I have just noticed you had posted your question(duplicate) earlier stating this happened a year ago. You can still try the recommendations but after a year the corrosion could be too bad to save phone.
Good luck.
hey my device is working, i thing water maybe inside a display or something?
i am all ready tried to power on it and its works just fine, but display :/
Gytis, You will have to disassemble the phone and clean all the connectors and board very carefully as recommended in the links I posted. Hopefully this will get the display working. You should stop powering on until you have cleaned phone up inside, by powering on you could be causing short circuit damaging the device further.
Oooo!! please, help me.... tell me it's fine, I have powered it on and off several times to see if it works or not but It's got really worse, do you think I could still save it? it's been a couple of days now that it was washed. :'(
crwdns2942667:0crwdne2942667:0 508
