The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Why my washer is not emptying
washer is filling but not emptying
my lid switch was not working replaced and am ready to go!
Glad I could help get you up and running ;-)
How do I know if it's the lid switch? Washing machine will fill but will not drain. I took the pump apart and there is no clog. There is nothing stuck in the drain hose either.
If your Kenmore 110 Series Washing Machine is not draining after a wash cycle, see the Kenmore 110 Series Washing Machine Won’t Drain problem page for possible causes and solutions.
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
JC Cotton crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,543
