Can this model be upgraded to ssd?
Hi I have the Samsung NP3--e5a-S07AU Notebook and was wondering if this can be upgraded to SSD
Thanks
Sean
Thanks
Sean
seanwp2 if your machine is a Samsung NP300e5a then you can simply remove the hard drive and replace it with a SSD as @danekjohnson has said it will greatly increase you boot speed and you will defiantly notice better battery life. If however the -- in the model number you showed above refer to some other model then I cannot say with certainty that this will work. Hope this helps
Yes you can place a SSD in your computer. This computer has a 2.5" spinning disk drive and you will see massive performance and battery gains from this kind of swap. You will need to find a sata 2.5" SSD. I have lots of luck with the samsung evo 850 drives.
Regards,
Dane K. Johnson
Cheers Samsung said that I couldn't lol :D
I assure you this is possible. This person did a complete teardown:
https://www.youtube.com/watch?v=WrMbmV2d...
The drive is under the door in the middle of the laptop.
Regards,
Dane K. Johnson
crwdns2942667:0crwdne2942667:0 3,515
My model is Samsung NP300E5A_S07AU I believe it is possible
crwdns2934271:0crwdnd2934271:0 seanwp2 crwdne2934271:0
