Repair guides and troubleshooting help for Maytag ice makers.
water not reaching ice maker
hooked up factory installed ice maker. bottom freezer. water is going on bottom of freezer
Water Inlet Valve
The water inlet valve opens to supply water to the dispenser and icemaker. If the water inlet valve is cracked or has a loose fitting, water will leak from the valve. Inspect the water inlet valve for cracks, and make sure that it is tightly secured to the water supply line.
It will also leak if the water pressure to the valve is to low.
amberdthomas crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 137
