Trackpad doesn't sit flush on new topcase
I had to replace the topcase on my air and while it works and everything went back together properly, the only way to make the touchpad work so it didnt sit loose was to turn the set screw far enough that the bottom slightly sits higher than the palmrest (photo below). The top of the touchpad thats closest to the keyboard looks normal where it sits slightly below the top case but the bottom is raised about 1 mm. All works fine but i'm worried about long term functionality and that it doesnt look like it did before. any help would be appreciated
