SIMM card inside the tablet
The small inter part of the SIMM card broke off in the slot. What can I do to get it out?
It's hard to say without being able to see it. I usually utilize a pick (VERY CAREFULLY) to try to pull the card out. Is it visible enough for you to take a picture?
-CW
Thank you so much for the information but the small card is not visible. You need a small flashlight because it at the bottom. The Geek Guy said he would need to take the back off.
Without a solution, I took it to the Geek Guys. They took off the back and took out the card. What a rip off. $20 to take off the back and investigate the problem then another $20 to remove the card. I will try to solve the problem myself next time with a pick.
If you do, just make sure that once again, you are extremely careful.
crwdns2942667:0crwdne2942667:0 556
