What are theses pins inside the phone?
I had to change my battery and screen of my Z3 Compact, he work from some days, but I when I got to change the rear camera, I lost the metal bracket that goes around the camera and now I phone wont turn on anymore... Just red light when charging..
That golden pins prevent the phone from being charged or turned on? Because as I lost the metal bracket so I think two of them arent pressed.
http://imgur.com/a/qWM6S
Have you looked at the full tear down on iFixit?
Sony Xperia Z3 Compact Teardown
That picture doesn't offer much detail... Try to retake it. I don't see any pins.
Hello, thank you all for the attention. I attached a new picture, please see the circle marked with the number "1" .. There was a metal bracket that supposed to hold the camera that I lost.
By the way, in the circle number "2" where was a plastic that jump out (the same that you can find 1 cm up) , but (I think) that unless I pretend to use the magnetic charger that shouldn't be a problem..
If the problem is the lack of this two pieces, knowing that I can't find to sale both, what can I do to make the phone turn on again?
Thank you a lot!!!
José Silva those are contact pins between the case (front cover) and the board. For example for the speaker as shown in the illustration....
If your phone worked before and quit working after you lost the contacts you will somehow have to replace them. You would have to show us exactly where it is located. A clearer image of what and where you lost it, might help. Post your images with your Question by following this guide
José Silva crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 185
