Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
battery changed, phone switches off randomly
i've changed my battery, and now it sometimes switches on and stays on, and sometimes randomly powers down, or, sometimes when i switch it on it keeps cycling to the apple screen over and over. the new battery was 57% and then charged up to 100% really fast.
i'm also almost 100% sure about the screws, i stuck them to tape in the right configuration and didn't tighten them too much.
Hi,
I would suggest trying another battery replacement, depending where you got it from, it could be a cheap, or faulty battery, try get a replacement. :-)
Probably a faulty replacement battery
Thelia from what you have said I think you have dislodged the gas gauge filter at the back of the battery connector. If you have tried the original battery and the symptoms are the same then a local repairer will be able to fix this quite easy. It is basically a false reading between the board and battery. I am sure you will find gas gauge posts on here for you to confirm this
thelia crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 80
