Gaming headset with around-ear headphones and removable omni-directional microphone. Shipped with Xbox One audio adapter and a micro USB update cable. Released 2014.
Jack snapped in two
The jack on my cord to my headset has snapped in two. Can it be fixed? Replaced?
It looks like the jack is a two-pole stereo jack. This fix will require some soldering.
  1. Find a 3.5mm (AUX) cable of sufficient thickness.
  2. Cut the end off of the headset's cord, and cut off about 3 inches from the end of the AUX cable.
  3. Strip about an inch off of the outside sheath of both cords, then strip about 3/8 inch off of the end of all the ends of all wires inside (there should be 2, plus a sheath or ground), and twist each internal wire so that it doesn't fray. Twist the metal sheath into a third wire.
  4. Slip on three 1.5" pieces of appropriately sized heat shrink tubing onto each wire, and slip on a fourth 2.5" piece over the entire thing.
  5. Match the colors of the wire to the end of the AUX cord, then solder the two together.
  6. Slip the heat shrink tubing that you previously put on over and use a hair dryer, heat gun or lighter to shrink it around.
jceresman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 478
