Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
crwdns2934591:01041crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Issues after housing replacement
I changed the housing along with a new lcd on my iPhone 6s plus.
When I turn it on. It sometimes works and sometimes doesn't prompting the plug in charger icon. But oddly it will actually turn on sometimes and after a 10 - 20 seconds will shutdown with no notice.
Does this mean the battery has been damaged during housing replacement.
Secondly the antenna on the top left wasn't coming off as I didn't know about the hidden screw under sticker and I ripped it off.
Now the little plate on the back has broken off but I sandwiched it back and screwed it down. Should I replace with new one?
Update (01/03/2017)
ok switched battery and now problem solved.
i have a new issue now. The volume button randomly presses itself especially the vibrate rocker? does the flex for volume need to be changed?
original flex solved issue and it seems i had battery issue too. now all is working fine
Housing replacements are, oddly, more tricky than it sounds. The first problem could be a bad battery. The second problem sounds like you need to replace it with a new one for sure
I know you probably have figured this out. But I'll post a guide, just in case
This is the antennae in the top left
crwdns2942205:01crwdne2942205:0:
they all 6 plus parts buddy. ihave 6s plus
Obahan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 107
