What is the small plug at the bottom rear? External Antenna?
Once you take the back cover off, at the bottom right there what seems to be a very small jack input. As it is located almost under the antenna plug inside, I wonder if this is where to plug an external antenna? I yahooed it all but could not find answer. Thanks
(PS I also Binged and Googled it...)
@moild post some images of what you are referring to. It might help if we can see what you see. Use this guide Adding images to an existing question for that.
