Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
My iBook G3 Is Having Keyboard Issues. What Can I Do?
Dear iFixit,
I am having Some Issues with the keyboard. There are (about half of it) some keys one the keyboard that if i press nothing shows up, not another letter, nothing. I wanted to reset the iBook to factory settings put read some internet articles and i do not hafve any restoration disks, i got it used. Is there any other way to reset the laptop without erasing the OS? I do not care about the information.
Thank You
crwdns2889612:0crwdne2889612:0 -1
please help me :)
Thank YOu, That Did NOT work, (Thank You For The Advice) but... IS there a possible way for resetting the laptop to factory settings without any Tiger Discs?
CaveCanem
Since an external keyboard would not work I suspect your problem is hardware related. I know of no way to reset to factory settings without the operating system disk. It sounds as though something may have been spilled on the keyboard or possibly a problem with the logic board. One other easy check you can make is to remove the keyboard and insure the ribbon cable and connector are in good condition and making a good connection. Link provided to help you. Good luck.
iBook G3 12" Keyboard Replacement
Try an externel USB keyboard to check if the troubles are software related. Any USB keyboard will do, even a PC one. If that works you will have to replace your build in keyboard.
good answer +
Thank YOu, That Did NOT work, (Thank You For The Advice) but... IS there a possible way for resetting the laptop to factory settings without any Tiger Discs? CaveCanem
cavecanemantiquestore crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 799
