SMC Problem Reference Code PFM 006
Fan is running all the time, while the laptop is totally cool and also well aired.
Diagnostics returns with SMC-Problem, Reference Code PFM 006.
SMC reset attempts do not change anything. What can be done?
Update (12/27/2016)
Dear Dan, No nothing spilled into the laptop and it did not drop or get banged. The worst that happened to it: it got transported several times in a padded back pack on planes and trains.
The story with the fan is lengthy. It started to act up last September but returned to normal after I stopped Drop Box to run all the time. Two weeks later the fan started up again for a month. One night 2/3 through backing up my home directory the fan stopped running again and everything seemed normal (when the fan is going full force start-up is very slow erratic, also the computer is very slow. Activity though is very low). Anyhow the fan then started to act up again about three weeks ago.
I wonder whether there is a fully temperature gauge.
crwdns2944067:011crwdne2944067:0
Can you give us some more background here. Did you spill something into your system or sit it down on a wet surface? Did you bang it?
crwdns2957956:0crwdnd2957956:0 DanJ crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Just letting everyone know that this is usually a case of moisture in the silly places ie the track pad I would be looking for signs of corrosion
crwdns2957956:0crwdnd2957956:0 jonnythompson1994 crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Hi guys. First time here. This post was pointing me in the right direction. I had a Macbook pro 15,4 Mid 15 Retina that had also the SMC problem and the PFM006 error code. Fan’s on max and CPU very slow. Freezing mouse etc. Problem solved after I disconnected the battery and the cable to the PCB from the trackpad/heat sensors. When connected them again Macbook was running fine. Thanks for the tip guys (and girls maybe)
crwdns2957956:0crwdnd2957956:0 Carlo Danen crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Hi,
I had a similar Problem with a Macbook Air 2015 13”. Kernel Task very high and no Audio.
SMC ErrorPFM 006.
I did an SMC reset, which did not solve the issue. I then disconnected the Battery cable from the Mainboard for 5 min. and reconnected again.
After this everything worked fine again.
crwdns2957956:0crwdnd2957956:0 Michael crwdne2957956:0 crwdns2950251:0crwdne2950251:0
SMC Problem Reference Code PFM 006 - In my case the trackpad got liquid damage introduced to it and needed replacement. Fixed the issue in 2015 A1398 MBP.
crwdns2957956:0crwdnd2957956:0 mobilemactechs crwdne2957956:0 crwdns2950251:0crwdne2950251:0
crwdns2934275:06crwdne2934275:0
