How to access timing belts
How to remove the covert to the timing belts on a BBA 2865 breadmaker machine
It cost me a lot of nerves to get the white plastic clips off. They are also a pain to clip back on later.
So finally, here the top is off, ready for the white plug to be unplugged:
The earth cable still has to come off:
Now take care of the on/off switch:
The switch cables can stay plugged in. Mine were so hard in, I feared to break them off. Just be careful.
Important for later assembly: the three spacers.
Now the way is clear to replace the timing belts.
Fixed. View from underwards:
Good luck! ;-)
Great tutorial, helped me a lot on a BBA 2594 machine.
Thank You!
Thanks, it helped me too clatronic bba2865
Regarding the power switch:
it is easy to disconnect - gently pull the contact pistons (at the ends of the wires going to the switch) out of the switch's contact terminals
Belt is at the bottom of the machine.
You need to:
crwdns2942667:0crwdne2942667:0 1,118
