Canon PowerShot A series point and shoot camera released in 2006, with a 6.0 Megapixel camera and 4x optical zoom lens.
DIY "hot" spring fix
I have an A530 that was included in the recall for the "hot" spring but I didn't know about it and Canon won't fix it now. Does anyone have a diagram of what the problem was and the DIY fix that I've seen talked about, but never described?
John Darago this was recalled because a little hinge spring in the door of the battery compartment can stick out and short the batteries. Result is poor battery life, and a hot battery door.
You could try to shorten the spring, use a small Dremel like tool with a cut of wheel or simply place a piece of electrical tape over it.
I don't know if all A530s are like this, but I took the battery contact plate off by removing the two screws. The back side of the plate had a slot that the arm of the spring was supposed to fit into. I guess when it was assembled, the spring arm wasn't placed properly. If you decide to examine this, be careful. There is a little spring behind the plate that could "spring" away.
Those springs in the battery doors are the major reason why I do not like to work on cameras. A royal PITA to deal with those :-)
John Darago crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 644
