Tivax MiTraveler Tablet model 10Q-8. Android 4.1 Jelly Bean Operating System.
Reset to factory settings
When I reset my MiTravler back to factory settings it comes up all the time to input some codes ( numbers) in order to proceed, how to bypass and reset manually
My mitraveler tablet is froze up need to reset it how do I do that
leroysimpkins, from pg.17 of MiTravler manual.
Restore default setting, if you want to reset the factory setting and erase all materials, please press,
Settings → Backup & Reset → Factory data reset.
  • Warning: Factory data reset setting will delete your Google account information, data and configuration of system and applications from downloading.** Please use this function carefully.
Link to manual below. Good luck.
http://www.tivax.com/media/downloadable/...
what about the up/down key while pushing the on button
leroysimpkins, Yes you can try that it works on some devices, also note below,
From page #3 in your manual. Important Notice
-If the device is freezing or stuck, press the reset button(a small hole) or
long press power button for 7 seconds.
-When the performance is slow after using some applications, it is
recommended to close running application in setting menu.
leroysimpkins crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 2,175
