Why cant I receive txt message
why cant i receive txt messages
If you've checked all obvious stuff like you're not in airplane mode, sending to valid recipient, etc, I would check the APN codes for your carrier and make sure your device is set to correct codes. I have had this issue many times before with MetroPCS. You can find the correct APN for your carrier by searching Google or calling your carrier. HOPE that helps.
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 98
