pto kills tractor when put in gear
replace pto switch 6 months ago and worked fine went to use tractor yesterday and when you put pto in gear it kills the engine what is the problem
@goatman your tractor is a JD870?
Could be the button under the seat. Unless your setting on the seat or holding the seat down some way, the tractor will quit running. Found this out when I was buying the used tractor and wanted to make sure the pot worked. Hope this helps?
garry mcbride crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 532
