Answering machine full how to delete messages
@unrea , Paul. link below will explain how to delete 1 message at a time or delete all. 2nd link is Uniden support for you manual. Good luck.
It said mail box is full but it's not what do i do to fix it
I also have an answering machine that says mailbox is full but it is not and has no messages. Nothing to delete. Can you help?
What is the make and model number of the phone with the answering system?
After you listen to all your messages, the message icon turns off and the
charge LED on the handset stops blinking. If it doesn’t, you can reset it:
With the phone in standby, open the menu and select Global Setup; select
VMWI Reset, then select Yes.
THANK YOU …..Stopped blinking
I do NOT have a so-called Delete button on my Uniden that I inherited with this apartment. I am so frustrated at having 32 old messages - and no telephone customer support service available from the manufacturer - that I am about ready to open my back door and pitch it into the woods!
And my GOD! that worked! When I typed that in, I was able to actually find a reference guide online .... you hit the button on the bottom of the base that looks like an arrow ... when the message plays back, you hit the zero with the line through it. Altho the sound was a piercing electronic squelch that probably disturbed the animals, it did go fairly quickly! PROBLEM SOLVED! Ok, not tossing the phone out the door ;)
What is the model number of the phone?
Jayeff , that's a good question ;) All I know is it says Dect 6.0.
So there is nothing else printed on the phone somewhere, under the battery perhaps or in /under the charger cradle then? That's very strange
Didn't think about that! I flipped it over and it says DECT2080-2
For Vtech LS 6245 you cannot delete all new messages, but can delete all old messages. So the fastest way to delete all messages that are new is to
1) Listen to messages
2) Skip them all with the forward button, this can be done faster than deleting each individual one
3) Go in to the answering machine menu and delete all old messages, it will now delete all the messages you just skipped :)
Y K
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 17,179
