Missing component on logic bord
I was going to replace the HDD om my Mac Mini Mid 2010 and managed to rip a component off of the logicboard. It's right next to the fan connector. Now the fan is stuck at full speed. Can anyone help me identify the missing component?!
Regards, Mattias
I don't have board view/schematic documents for this particular board, but it is easy to figure out which component is missing;
1. Google your board number followed by schematic/boardview. For example "820-2577-A schematic".
2. Once you have downloaded both documents, use the board view document (with a board view program) to locate the component. Click it, and it will give you the name.
3. Go to the schematic and search for the name of the component. It will give you the value of it, so you can find it on Farnell/Mouser/Digikey. If it says "no stuff", it means there is not supposed to be a component there.
You will then need to solder the new component on. Also, the component above it will need to be seated flat to the board, since you knocked this as well.
Update (11/20/2016)
@oldturkey03 Didn't know that, that's not good :(
@fogsvans Best solution would be to buy a non-functioning model of the same year and swap the components, unless you can find a dead board on Aliexpress/Alibaba?
@reecee Mac Mini schematics and/or boardview are not really available.
@fogsvans
Did You find answer? I have the same problem, one component (L6500) is missing, seems this is not resistor (R), but inductor.
Edit: Found schematic from same generation iMac and the missing component is BLM15EG221SN1D, 220 ohm, 700mA inductor.
Mattias crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,209
