iPhone 6+, touch ID doesnt work after screen change. Orig home button
Thanks for looking. Did a 6 plus screen, no issues at all taking it apart. Battery was the first thing disconnected. Removed home button, camera, etc, no issues at all. Swap everything and before I put the covers on for the battery, screen/home/camera cables... I test the phone. No issues. I put all the covers back on, seal it up and then get a cannot setup touch id error...I take it apart, remove the home button cover, test and its fine, put the cover back and get an error. Remove the cover, reseat the connector, no error, put cover on, no error. Seal it all back up, restart, no error. Customer takes it, goes to setup his touch id and it wont work. Any thoughts? Would you think its a pinched cable issue or an issue as stated by zzcharlyzz on Sept 20th at this link Touch ID not working after screen replacement?
Is it possible it wasn't seated right, then I got it seated right (when I reseated, the battery was not disconnected) and then it got stuck in that loop that wont recognize it?
crwdns2942205:01crwdne2942205:0
Thank you both, I cannot see how the sensor itself could've been damaged. Done so many of these and never had an issue. Had no problem removing the button. Everything was done powered off. Its a regular 6 plus...I ordered a new shield/cable so that when I have the phone in hand I can try the disco power, reseat cable, restart scenario and if that doesn't work then I will swap the cable and see what happens. Just trying to see if there is anything else it could be, so that when I have the phone, I can try other options. As for DFU, as its not my phone, I am trying to do the simpler/less invasive options lol
crwdns2934271:0crwdnd2934271:0 outofrng623 crwdne2934271:0
