The Acer Aspire One A150-1570 is a netbook with a 8.9" display. The model number is ZG5 AOA150-1570. It was released in 2005.
Why is my computer not charging?
I've recently been trying to charge my laptop, but every time I plug in the charger my laptop won't charge.
You can try to toggle with the connection in the charging port between the Acer and the charger. The charger might be getting old and that could result in a short in the connection. If that does not work, you may want to try possibly plugging the charger into a different outlet to see if it's not the charger. If the two choices don't work, you may need to acquire a new charger for your device.
it might be a problem of charger even it look working with green led you must try another charger and you must try another battery then try to update your bios
if nothing happen its ic charge
Ismael Valdivai crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 371
