Joystick keeps drifting to the left?
The cursor keeps moving to the left even though I'm not moving the joystick left. How can I fix this?
my right joystick is stuck it keeps moving on right side. How can i fix this
On Windows, try going to 'Game Controllers' in the Control Panel. Select your device, go to the 'Settings' tab, and click 'Calibrate'. Follow the instructions and you should be good to go!
I already tried but nothing happened😭
crwdns2947821:0crwdne2947821:0
If you’re having this problem, you probably just need to calibrate it. Go to Window’s search bar and enter "joy.cpl" then run it as an administrator. Then, select your controller and click on properties. This will open a new window with two tabs. Select “Settings“ then “Calibrate” and follow the instructions.
Peter Takahashi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,744
