A digital camera designed and manufactured by Sony in 2012. A 18.2 megapixel camera with Wi-Fi, GPS, and a memory card slot.
Program Selection Wheel not working properly
Hi,
hope you can help: when I select a program it is often lost. For example: I set the wheel on P but on the screen the selection is - M. I have to move the wheel just a little bit to have the right program set again, but sometimes it's immediately lost again.
Maybe dust under the wheel? How can I clean it?
Thanks,
David
Now the wheel works (even if ha become a little bit harder to roll), thanks!
Davide
David, Glad to here it is working, pretty sure it will start easing up with usage after the cleaning. have a good day.
@catchtherainbow , David, Sony Cyber Shot, remove the battery, squirt a (little) 90% Isopropyl Alcohol under selection wheel and blow out/dry with canned compressed air. Repeat a couple time and this should clean out the dust/dirt from under wheel.
If this does not correct the issue button internal stops are probably worn and button assy. may need replace to correct. I will post a tear down guide if you wish to dig a little deeper into your device.
Sony Cyber-shot DSC-HX20V Outer Case Replacement
David crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 1,663
