Water spilled on my resume note 3 phone
I spilled water on my phone it has tempered glass I wiped it immediately, I think water dint get inside
n phone is working properly will this affect in future
Hi,
Unless you open the phone and check to see if there was any water ingress you will have to wait and see. If it does start to exhibit any problems at all the following information may assist you.
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Do not be tempted to place the phone in rice.
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,299
