Why does my browser crashes after a few minutes of usage?
While browsing, the browser continually crashes after 20-30 minutes of usage.
You may have issues with the operating system memory management, do the following to correct the issue
1- Install the ADB Driver Support
2-Apply the tweak tool found in the ADB Driver; if it still does not work, contact the Cruz Support Assistance
Your Browser??
Ok! then, you can see one of the browser chrome crashes problem and how to resolve it!
Chrome Freezes or Crashes
1) First of all delete the Local State file which holds some of the Custom Settings, and see if it helps you. To delete the Local State file, follow these steps:
a. Close Google Chrome
b. Open Windows Explorer
c. In address bar type in %USERPROFILE%\AppData\Local\Google\Chrome\User Data
d. You’ll find “Local State” file there. Delete it
e. Open Google Chrome and see if has helped.
2) You could also try the following!
Rename the Default folder which has all the Google extensions, Bookmarks, History, Jumplist icons etc. The reason why we are renaming it is because if it’s not the cause of the random freezes and crashes, then we don’t have to lose all this information.
To rename the Default folder, follow these steps:
d. You’ll find the Default folder here. Rename it to “Default.old”
e. Open Google Chrome and see if this has helped stop the crashes.
3) You might also want to checkout if the Flash extension is the culprit and causing the crashes, and see if it helps. To do so, follow these steps:
a. Open Google Chrome
b. In the address bar type in “about:plugins”
c. Find “Flash” and click on Disable
d. Restart Google Chrome and test it now
If it helps, then uninstall Flash from the Program and Feature and reinstall it. To reinstall Flash, you may follow this guide on Adobe.
4) Check if your Google Chrome Shockwave Plugin is creating problems. Find & Disable Power-Hungry Extensions in Chrome using Chrome Task Manager.
5) Well, if none of these steps help you, you might have to consider reinstalling your Google Chrome browser. To do so:
a. Go to Programs and Features and Uninstall Google Chrome
b. Then open explorer.exe and go to %USERPROFILE%\AppData\Localc. Delete “Google” folder
d. Download Google Chrome and install it again.
This should help! If it doesn’t, you may want to reset Chrome settings.
Browser are computer programs when an unexpected error condition occurs, and on that time it is handle by existing code..... in many cases it happen that browser try to make disable plugin untill the activation of actual plugin.
Chrome relentessly shut down after a minute or so.
I tried turning off all extensions, uninstalling and reinstalling chrome, uninstalling and/or disabling malware protection, and a few other things. No go.
Problem solved: I migrated to Firefox.
crwdns2942667:0crwdne2942667:0 5,094
