Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
EZGO rear wheel removal
I have tried every hub removal device I can find. The hub won't budge. I have sprayed with every type of cleaner or blaster I can find. Tried heat w torch. It won't budge. Any advice? My next attempt is to use a grinder and cut the hub off.
@jthawthorne what model EZGO do you have?
Do away with the torch and buying a puller! Here is what I did. Take off the wheel and the castle nut and spray with PB Blaster. Let soak 15-30 minutes or so. Do not put the castle nut back on, but put the wheel and lugs back on. With the cart still lifted on the one side, beat the back side of the tire with a rubber mallet several times and it should come loose.
I tried everything mentioned here - a few different penetrating oils (including PB Blaster), a hub puller with center push screw, a hub puller with a slide hammer, a torch, a regular hammer, putting the wheel back on and beating it. Didn't get even a tiny wiggle. Finally took the angle grinder to it and made mincemeat of the whole thing. It did come off, but I nicked up the axle in the process, so I get to replace that, too.
Regarding old Turkey's fix, I think it's misleading to say the least. According to every diagram I've seen, the hub and the drum are part of the same piece - in that regard, no, you cannot remove the hub without removing the drum, but it's because they're the same thing. And it's not the brake drum that's held in place by 4 bolts, it's the backing plate - which is also the piece that holds the brake pads. The diagram included is unfortunate, since it cuts off the name of all the relevant pieces. I've seen elsewhere that #102 is the hub/drum, and #89 is the backing plate.
@jthawthorne you have not told us what model EZGO you have. Those details are sometimes important. You keep on talking about removing the hub and I am not sure why you are trying to remove the hub to remove the brake drum. All you have to do is to remove the cotter pin (107), the castle nut (106) and back your brake lining off with the help of the adjuster. the tap the drum with a hamer a few times and it should pull of. You may consider posting a couple of images of what you are looking at with your question. Use this guide for that. You cannot remove the hub unless you remove the brake drum since the hub is held in place by commonly 4 bolts that are on the inside of the assembly.
nothing worked.........took nuts of backing plate..puiied backing plaie with hub..worked
@jthawthorne , John, You want to remove a stuck on brake drum correct! When they are stubborn like this,remove cotter key and castle nut, make sure park brake is fully off, some times there will be a ridge on the drum from wear and you must locate the adjuster and turn adjuster star wheel to release/decrease brake expansion allowing more play for drum to slip over worn ridge on drum. Spray spline liberally with a good penatrent oil. Hit drum with heavy hammer hard multiple times on the face edge of drum, this will normally send a good vibration to release drum from axle. Still not releasing the next step would be to heat drum at hub till almost red hot and then hammer off. If it is still not budging, time to bite the bullet. Get out the angle grinder with cutting wheel, cut 2 slot in the drums hub perpendicular/across to each other, cut almost to the axle spline(stop before damaging axle), then with a heavy hammer and cold chisel, place chisel in cut slot and hit solidly rotate to other cut slot in drum hub and repeat. This will spread/crack the hub from axle spline after a few tries, allow hub to come off. Now of course that means time for new hub $40-$50. Anti seize spline before putting drum back on. Good luck.
Check for retaining clip/c clip and remove. Check the attached link for instruction on hub/axle removal. Check the attached links,instruction and guides, Good luck.
http://www.buggiesgonewild.com/electric-...
https://www.manualslib.com/manual/836546...
The rear hub seems to be frozen in place. I have tried all types of wheel/hub pullers. All I have accomplished is destroying the end of the threaded spindle.
@jthawthorne , John, You want to remove a stuck on brake drum correct! When they are stubborn like this,remove cotter key and castle nut, make sure park brake is fully off, some times there will be a ridge on the drum from wear and you must locate the adjuster and turn adjuster star wheel to release/decrease brake expansion allowing more play for drum to slip over worn ridge on drum. Spray spline liberally with a good penetrent oil. Hit drum with heavy hamer hard multiple times on the face edge of drum, this will normally send a good vibration to release drum from axle. Still not releasing the next step would be to heat drum at hub till almost red hot and then hammer off. ((Continuation below))
@jthawthorne , If it is still not budging, time to bite the bullet. Get out the angle grinder with cutting wheel, cut 2 slot in the drums hub perpindicular/across to each other, cut almost to the axle spline(stop before damaging axle), then with a heavy hammer and cold chisel, place chisel in cut slot and hit solidlly rotate to other cut slot in drum hub and repeat. This will spread/crack the hub from axle spline after a few tries, allow hub to come off. Now of course that means time for new hub $40-$50. Antiseize spline before putting drum backon. Good luck.
https://www.youtube.com/watch?v=DR9kg_RA...
Take a look at this guide for axle replacement. It looks like the hub may be bolted on from the backside: https://www.youtube.com/watch?v=12NT57t2...
Not looking to pull the axle. I'm trying to get the hub to release from the spline so I can service the brake linings. Using all types of hub pullers, I have only accomplished damaging the end of the threaded spindle of the axle. I have sprayed, heated and done all I know at this time to get this hub off.
LOOK at the guide and see if it is bolted on from the back!
It will come off easily if the brake isn't locked. No way it will budge with the brake engaged.
John Hawthorne crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 140
crwdns2942667:0crwdne2942667:0 20,783
