The Shark Rocket HV301 is the second installment of vacuums in the 300 series. It is a two-in-one vacuum that comes with several attachments, making it capable of cleaning on different surfaces. Its sleek and lightweight design make it easy to maneuver around any household.
What do I do if my device will not suck anything up?
I have plugged in and turned on my vacuum but it won't pick up any dirt particles. What should I do?
If your device is turned on but won’t suck anything up, try emptying your dust cap of any debris regularly or replacing it if it is very old. Also check to see if there’s is any build up in the vacuum tube by turning off the device and checking with a flashlight. If you find anything, just use a long and dull stick to remove it. If the problem persists you may have a tear in your vacuum hole, so follow the guides to remove it.
Shelby Baccala crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 518
