Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
No charging and reboot after release the ligthning cable
Hi @ all,
so i have the problem that the iPhone 6 wit IOS 10.1 will not charge.
If i put on the Lightning cable, it will not charge. Battery was 4%.
When i get off the cable, the screen gets a little bit "rainbow" and start a reboot with the apple Logo.
In hope it will work again, i change the lightning connector and the battery.
After that the Battery was 75% BUT also the same failure.
I also used different cables and charger. Nothing works.
Can anybody help me??????
Thanks in advance and sorry for the bad english
Patrick
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
Whenever there are charging issues with a phone, these are the steps to take:
  • If the phone boots, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. Anything less than 70% of design capacity will require replacement.
  • If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it says it's charging.
  • Insure you are using high quality Apple original or MFi certified cables and chargers. Cheap chargers can damage the charge circuit on the logic board.
  • Replacing the battery is always a valuable option
If a new or known-good battery doesn't solve the problem, then you likely have a logic board issue.
Paku83 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 114
