Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
crwdns2934591:03530crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why does my phone turn on but wont charge (iPhone 5s)
I have just replaced the casing on my iPhone 5s, everything else works but the lighting port. When I turn the phone off and then plug it in it will turn on but when it turns on it wont charge. I tried cleaning out the port as well as using different cables. Please help me come up with a solution.
crwdns2942205:01crwdne2942205:0
They are reletively easy to change out btw
Replace the lightning flex by @benjamen50
crwdns2942205:01crwdne2942205:0:
I am sorry I miss read that i though it was the other way around, i though it was not holding a charge. Sorry
It sounds like a bad battery. It sounds like it would need replacement. I have the same problem with my 5s, I replaced the battery and it was working as new again.
Edit:
This looks like the battery you would need:
iPhone 5s Battery
crwdns2886500:0iPhone 5s Batterycrwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 5s Battery
$29.99
I had just replaced the battery could it be the lightning flex?
I used a ifixit replacement
I doubt its the battery because if it is not showing charging when its turned on then it must be the charging dock ribbon cable assembly gone faulty.
Most likely the ribbon cable suffered some damage from tearing when it was pryed out of the old iphone housing.
ok @benjamen50 I bought the ribbon cable
Robert Hayek crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 69
