How do you get to drain plug
where is drain plug in ice box
Dale, GE Profile French-Door Refrigerator freezer drain, hopefully the attached vid's. will show how you can access drain plug. You can also do a google search yourself(GE Profile French-Door Refrigerator freezer drain ) lots of info. out there.
thank you very much. took hair dryer and it worked.
Cause 1
Clogged or Freezing Defrost Drain
If the defrost drain is frozen, the water will overflow the drain trough and drip down to the bottom of the compartment. This water can eventually leak onto the floor. Check the defrost drain to determine if it is clogged or frozen. If the defrost drain is frozen, thaw the ice. In addition, flush the drain with hot water to ensure that it is clear of debris.
Cause 2
Water Inlet Valve
The water inlet valve opens to supply water to the dispenser and icemaker. If the water inlet valve is cracked or has a loose fitting, water will leak from the valve. Inspect the water inlet valve for cracks, and make sure that it is tightly secured to the water supply line.
Water Inlet Valve for your GE Refrigerator
Water Inlet Valve - Part # 1472740 Mfg Part # WR57X10082
RepairClinic Item #1472740
Water valve
$108.71
Cause 3
Water Filter Housing
Inspect the water filter housing for cracks. If you discover any cracks in the water filter housing, replace the housing.
Water Filter Housing for your GE Refrigerator
Water Filter Housing - Part # 1477316 Mfg Part # WR17X12469
RepairClinic Item #1477316
Water filter housing and tubing with bypass cap
$175.40
how do I get to the water filter housing ?tried taking inside apart but was afraid I wouid break something.
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 14,545
