Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
crwdns2934591:0295crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Can't get top right corner screw back in.
I took apart my iphone 4 and, as expected, had trouble removing the top right screw (near the audio jack). Now that I am trying to reassemble, I CAN NOT get the screw back in. I have been working on it for an hour.
I am using the tool kit from ifixit and the screw driver hand is too thick to be able to get a direct line on the screw. I need some advice on how to proceed.
1. Is their a screw driver with a longer thinner shaft that might work?
2. What happens if I leave the screw out altogether? (I did try that but the reassembled phone is unresponsive.
Any other ideas?
Hi !
As long as this screw is a contact screw, there's no surprise about your phone not responding once reassembled.
I suggest that you use different screwdrivers, not being able to give you an accurate reference as long as I no longer own an iPhone 4. If you still can't manage to screw it or that the head is a bit damaged, some tools sold f.e. at iFixit may help you. I personally use this one for damaged screws.
crwdns2886500:0Screw Extracting Plierscrwdne2886500:0
crwdns2934075:0crwdne2934075:0
$19.99
The screw head is still undamaged. I just can't get the screw driver and driver head alligned.
Have you tried with a flat one ?
A S Koski crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 48
