Repair guides and support for coffee makers by Keurig including the K-Cup systems.
model k48 keurig lights flashing
My model k48 has been unused for several months, but still in the house and upright. When I plugged it in, all the lights started to flash and would not stop. Customer service was of no help and offered me a discount on a new one. Anyone have a solution other than buying a new one? Thanks.
Try resetting the Keurig by pressing the auto-off and both the cup size buttons simultaneously. All the lights should go dark and then return to normal. Thanks to Amazon user PJP for the suggestion!
crwdns2944067:011crwdne2944067:0:
Did the trick...Thanks
I did what you said and it fix my keurig machine thank you very much for your solution.
Thanks for the tip. Enjoying a fresh brew right now
Thank you!!!! It worked!!!
What worked, I don't see a solution?
crwdns2934275:06crwdne2934275:0
Thank you, it worked!
Did not work. Still flashing Ugh
Tried every solution....unplugging to reset,cleaning needle,making sure water tank is sitting ok and pressing simultaneously the large and medium cup sizes.All lights are still flashing.Even tried a new outlet. Keurig is out the door ,I am back to a reliable drip coffee maker
nicklomele crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 22,762
