Problem with network broadband always going down on home/work
Hello, i have some big problems with the Op2 network broadband, i can get signal in the streets but at home/work i can't, can you help me with it?
This is a network issue, not a hardware issue.
I use a OP2 and get great signal inside and out. If you want to diagnose it yourself, download any LTE analyzer from the Play Store. You will be able to see the signal strength inside your home and work and outside.
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 75
Hi,
What type of home / work building is it? If the work place is in a steel and concrete building, this will reduce the signal strength. also at work if there is a lot of interference generated by machinery this will do it. At home if you have a tin (iron?) roof etc this also deflects signals. At home stand near a window and see if the signal improves, same at work.
If other phones work OK in either environment then it is most probably in the design of the aerial in the phone itself, or if you have you got the phone in a cover or case, try removing it and see how it goes.
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
