Hewlett-Packard began manufacturing personal laptop computers in 1993.
crwdns2934591:03326crwdne2934591:0 crwdns2934593:0crwdne2934593:0
My laptop is showing blue screen of death
whenever i tried to use my hp 15 p 202tx laptop my laptop start and windows on
but after some time it shows blue screen with smiley face with error Say
"WHEA UNCORRECTABLE ERROR"
i have changed Ram,HDD and done Recovery but it didn't work
please help
crwdns2944067:04crwdne2944067:0
Did you try a clean install without putting back the recovery?
yes i did tried clean installation of window but sometime blue screen appear
while installing window
i know the blue screen when installing windows its probably because the speed of optical drive or hard drive I would recommend you to put windows on USB recommended to be USB 3.0 but 2.0 will work this link can let you install windows 10 official https://www.microsoft.com/en-us/software... but there is some issues u will need good internet you will need another computer maybe your friend or something when you download the file it will say upgrade this pc or create installation media for another device you are gone choose create installation media then you will choose what to install on you will choose you USB then it will make everything for you plug into your laptop and run the installation
I already tried that but even clean install window has same problem
crwdns2933315:06crwdne2933315:0
Go to your BIOS and change to factory settings. If you can get the Laptop to work my advice is to get the latest video card drivers if possible. (Some laptops video cards will not update.) Also if you still have windows updates you should get them all until there are no more available. Also if you cannot get the laptop up the check you HDD to see if it has any errors and check all your memory cards to see if they are in tight.
You need to get the updated video driver for your system which a search says it is
NVIDIA GeForce 830M (2 GB DDR3 dedicated)
Bsod appear three times while i was installing the drivers after installation
It shows again
Try a Live CD like an Ubuntu LIVE CD and boot your computer with it. See if that works. If it does then your hardware is good if it doesn't then there might be something wrong with the computer.
when you said you installed another HDD was that a NEW one? Get a cheap NEW one.
Install a basic system on the drive and see how it goes.
crwdns2942205:01crwdne2942205:0:
yes i did install the new HDD but it didn't work
How to Fix Error “whea_uncorrectable_error” on Windows 8.1, Windows 10
Quick solution to fix “whea_uncorrectable_error” in Windows 10
Step 1: Download this PC Scan & Repair tool
Step 2: Click “Start Scan” to find Windows issues that could be causing “whea_uncorrectable_error” in Windows 10
Step 3: Click “Start Repair” to fix all issues.
Solution 1 – Disable Overclock in BIOS
The most common fix for whea_uncorrectable_error is disabling overclock from your BIOS. To do that, just follow these steps:
Open Start Menu and go to Settings
Go to Update and Security, and then to Recovery tab
Click on Advanced Startup and your computer will restart
On advanced startup, Go to Troubleshoot, then Advanced Options and then UEFI Firmware Settings
Click Restart
After the computer is restarted, it should open BIOS automatically, so go Advanced tab
Than to Performance, and look for Overclocking
Make sure overclocking is disabled
Save changes to BIOS (by pressing F10 on your keyboard), and start your computer normally
After disabling overclocking, you shouldn’t face this issue anymore, but if it’s still present, check out one of the following solutions.
Solution 2 – Start Windows in Safe Mode and Check for Drivers
Reboot or close the Windows 8.1, Windows 10 PC
When the PC starts press “F8” on the keyboard or another combination would be “Shift + F8”.
what do it mean it keeps rebooting
Window 10 users often face blue screen of death errors. I faced this issue before and I tried like 5 different methods. There are several reasons that can cause this error. I cant explain every step in detail but I think anyone who is facing this issue would be able to understand or you can read this article: Fix WHEA_UNCORRECTABLE_ERROR (Thoroughly explained)
One of the following step will sort out the problem:
1. Disable Overclock in BIOS
2. Fix Corrupted or Incompatible Device Drivers
3. Uninstall any recently added Application
4. Fix Corrupted Windows System Files
5. Use Memory Diagnostic to fix Memory ( RAM ) Errors
6. Scan and Check Hard Disk for errors
7. Fix Corrupted Registry Files
8. Restoring Windows back to an earlier point in time
Go to your BIOS and change to factory settings. If you can get the Laptop to work my advice is to get the latest video card drivers if possible.if this doesn’t work you might try to find another solution here.
Sunny crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 5,998
