Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Itunes error 4013 after screen and battery change
i've changed a screen and battery on an Iphone 5S, after that it goes directly to "Connect to itunes" on startup screen. I Connect it, get the "update or restore" question and Choose restore, but it wont go on. I've put phone in DFU and get a phone is in recoverymode, start the recovery and it starts the "getting data", then the prepeare phone for update. Screen turns of, apple logo comes on and the the screen turns red or blue (changes from one to the Other if i try several times) and turns of and error 4013 shows up. I've turned antivirus of, firewall of, reinstalled Itunes on computer, checked computer for updates. But it just Returns error 4013.
Any thoughts ? suggestions ??
I've tried With 4 different batterys and 2 different screens, no change.
crwdns2944067:06crwdne2944067:0
Did you try it without the front camera cable plugged in?
How was the battery removed, was it pryed from the left side of the battery only and not the top or right or bottom side of the battery?
Think i've tried With it and without it, but not 100% if i've tried without.
Tested With Other screens now, With and without front camera and still the same. It starts to "restore" and the screen turns red og blue and reboots
battery was removed With heating up backside, then prying from left side.
I have similar problem, just want to add few things i have tried:
1) Took out Screen and connect to itunes - can perform Restore & Update successfully
2) Took out battery and left for a while - Open connection, phone can be used but will have similar problem after restart
Nand chip must be removed, then formatted with a chip reader, then reinstalled. Jessa just released a video on this issue...
https://www.youtube.com/watch?v=qab9o9pY...
Hi
Have a look here for a solution
https://support.apple.com/en-gb/HT201444
Thanks
If you've read what i've tried that solution has been tested ofcourse. If it was that easy i would be one happy camper
Apple support is a great way to get business for Apple, not to solve your issues.
Hi, i have this problem with iphone 6s and am getting error 4013. i dont know if you fixed your phone or what ever but my phone was not working properly and shutting down every 3 minutes. and i see that the battery is saying, a not reconized compenent and then it got to 100% battery health. then i used the phone like normal and it worked until i shuted it down and powered back on. it was stuck on recovery mode but as i did was before this happened when it worked a little again i used a panic log program that identifies panic logs. i got a indicator that the battery was problem. even tho it says 3.8 volts the battery may is jsut broken. then i remembered that the iphone could not identify the battery so its a huge chance thats the problem. try a new battery again and try using 3utools then to exit rocevery mode. good luck.
thomas crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 5,931
