No reverse on my golf cart
My electric golf cart lost its reverse can I fix it myself or do I have to take it in to a service center?
@gerryr, this could be as simple as the reverse switch being the problem. It is a mechanical contact and could be not making the connection. You can check that by switching the wires from the forward/reverse switch and see if you now have only reverse. If so, you know it's the switch. You did not tell us if your cart has a backup beeper and if it still comes on. Also, let us know if this cart has a dash mounted toggle switch.
2008 yamaha cart with back up buzzer
what if its not the switch?
I replaced the forward reverse control board. Now I have no reverse. Reverse worked prior to replacing control board.
@mikegolf have you tried to switch the wires to see if you then have reverse but no forward?
Hi my ez-go 2005 txt cart suddenly decided to not go in reverse ! the reverse alarm sounds but the cart won't go ! it will run forward when I push on the rocker switch. I checked the contacts behind the switch and they are ok no broken or frayed wires.
mine was the micro switch on the passenger side of the forward reverse switch. I just bent the prong put on the lower side of the metal just below the white tip of the switch. This way it pushes further into the switch housing.
I have a 1998 club car and it was going in reverse with the reverse beeping noise and NOW it not going in reverse are forward
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 111
crwdns2936753:030crwdne2936753:0 363
crwdns2942667:0crwdne2942667:0 61,367
crwdns2944067:09crwdne2944067:0
Would you give us your model number?
crwdns2934271:0crwdnd2934271:0 mayer crwdne2934271:0
EZGO textron serial number 833198
crwdns2934271:0crwdnd2934271:0 gerry crwdne2934271:0
@gerryr and the make of your cart as well :-)
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
I find nothing but EZ-GO on the cart
Okay lets get to work. Based on your serial number you have a :
Make: Medalist
Type: Electric 36 V
Model: Electric Medalist
Year: 1994
Sounds about right?
crwdns2934275:04crwdne2934275:0
