exsaults gets red hot
i have to take bolt out of cam shaft censor advance the timing to get it to rev and run . but exsaults pipe gets red hot .
crwdns2889612:0crwdne2889612:0
2
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 131
@landfordjoseph1234,
It sounds like you're having problems with compression. What was the original problem with the cam shaft sensor? No start?
The fact you're getting heat problems on the exhaust leads me to believe that you've advanced the timing much too far. Probably running very rich on the timing which explains the easier start and hot exhaust. You may also be experiencing a misfire. Is the motor running really rough when you do get started up?
crwdns2934271:0crwdnd2934271:0 Daryl Metzler crwdne2934271:0
Do you smell rotten eggs? if you do, it means your catilitic convertor is bad, This will cause exhaust to get hot. Good luck.
crwdns2934271:0crwdnd2934271:0 Deleted crwdne2934271:0
