Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
Re-aligning print heads doesn't solve the problem....
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
I ran the cleaning cycle several times and it didn't help. Does the printer head need to be changed?
Khemchand Ramcharan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 4,824
