Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
iPhone showing black and white stripes
Hello!
My neighbours iPhone is only showing these black and white stripes.
When I change the display it's not showing anything (and I tested the new display on my own phone it definitly works!)
The old display sometimes shows these black and white stripes and sometimes it turns full white then black again.
My PC however seems to recognize the iPhone and it's also showing up on iTunes.
But it seems that I can't find a fix for the screen problem.
Here is the screen:
http://i.imgur.com/XjVKN12.jpg
Hi there,
This youtube video might help you: https://www.youtube.com/watch?v=nJCZJwrk...
In which he opens the phone up, cleans all the sockets that attach the screen to the motherboard with a toothbrush, and then secures the cables back into their sockets.
Note that he is working on a 5s, in order to open a 5 you can follow this guide, which is essentially the same but without the booby trapped cable connected to the home button that you will see in the video.
iPhone 5 Screen Replacement
Hope this helps!
Hi, I'm gonna try that, also cleaning with 100% alcohol and puttin' a new screen.. hope that works
Okay, it's not the display. I cleaned it with alcohol and it's still only showing these black and white stripes.
Aw man, I wish I had another suggestion for you, but that was my best guess... I'll keep searching the internet and let you know if I find an explanation.
Thanks, ye I think I found some posts on some weird russian forum saying that it's an issue with the board. Some circuits are screw'd (seems to be a common problem with 5c's tho) - welp thanks for your help anyways. I think I'll just sell it on ebay, cause from the outside it still looks fine.
This is happening to me to, I am doing this on my computer, this has happened two times before but the phone usually worked again after a couple of hours. I know this was like 3 years ago and it probably is working again so any tips or should I just wait?
I had that problem too, but alcohol can sometimes break the circuit, try with a toothbrush, without alcohol, and if that doesn’t work, buy a new motherboard.
Yes sounds like a failed chip on the board.
dieuhientran63 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 13,823
