The printer prints blank paper
The toner is new but nothing prints on the paper. It feeds like it should but spits out blank paper.
Here are the steps to fix the brother printer printing completely blank pages issue.
1. First of all, you should restart the devices, and then give a print command.
2. Let’s cancel all print command, and then visit the printer properties, let’s see if your printer is showing available in the queue or not?
3. Most of the time, people are getting the blank page from their brother printer due to the ink cartridge issue, so you need to assure that your printer has enough ink to print a text on the paper, if it doesn’t have enough ink, you may replace the ink cartridge as well.
4. Apart from this, you may have the ink cartridge issue due to the installation issue, so you should uninstall the ink cartridge and reinstall the cartridge again. now give a new command, let’s see if your printer is allowing you to print a document or not?
5. Sometimes, you may be getting the blank pages as an output due to the driver issue, whenever your printer is not printing the documents, you should take out the driver from your pc, and install a new driver on your pc.
6. After using the above steps, if your printer is not allowing you to print anything, I will suggest you to factory restore your printer, and then reconfigure it.
LOL of-course a silly question @djmetzle but surely that the first question to come to mind .. then probably resitting the cartridge...
but highly sure it is that plastic protector either not removed or partly broken inside as mentioned by @djmetzle
If your brother printer is currently printing blank pages. here are the steps to fix it easily.
# Clean up the printer properly.
Once you will make these changes, the brother printer will start working fine. in case, if you are still dealing with some other issues. please feel free to visit: why is my brother printer printing blank pages?
Did you use the correct number of toner ink in the cartridge? There are many numbers in ink and each printer supports only a fixed number or type of ink. If you will change the type of ink it won't print.
toner cartridge is not install
Why this, I have even buy a new cartridge
crwdns2942667:0crwdne2942667:0 14,239
Penny,
Silly question, but did you remove the plastic protector strip when you installed the new toner?
crwdns2934271:0crwdnd2934271:0 Daryl Metzler crwdne2934271:0
