wifi problem after lcd and back cover replacement
hello, i'm Dan, i have a problem with my z3 compact's wifi. I replaced the lcd and the back cover, and the wifi don't work good... The signal at 2,4GHz is so bad and at 0 mb in download, with the 5GHz is a bit better but not enought. I don't know where is the wifi antenna, and if i could touched it or broked it when i moved the motherboard or others.
Check connetor on mainboard and plastic main frame. Wi-Fi antena is in a frame. Check screws and spring connector on mainboard (it goes to frame). Maybe you can broke it or distort it.
dan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 942
