A series of Gigabit NAS desktop drives of 1TB, 2TB, and 3TB varieties, made by WD in 2010.
accessing the HD in MyBook Live
I had this MyBook for a few years, backing up to it my photos, music. Now, looks like it is dead. I extracted the hard drive from the MyBook enclosure and trying to connect to my PC (running Windows 10) using one of those "USB To SATA/IDE Hard Drive adapters." The drive shows up in the file manager fine, but if I click on it , it will show "G:\ Is Not Accessible. Invalid parameter". Any ideas, recommendations on how to recover/extract files? I really need those files...
crwdns2944067:04crwdne2944067:0
Please give us the exact model number of the MyBook and make and model number of the hard drive.
I have the same issue with a WD MyBook Live model WDBACG0030HCH-00
Hola Felix did you successfully complete or recover your data from this HDD? I have the sme issue and I dont want to format the HDD
I ended up dismantling the whole enclosure and re-using the hard drive. I was able to extract some data from the HD.
It looks as if your HDD is corrupted. You should try some data recovery software or take it to a professional to get your data off of it. I've recovered data off a hard drive formatted for mac using a mac so i dont know how it works with windows but from the way it sounds it got corrupted or worse the head got stuck on the disk. Try recovery software or take it to a pro
Hope this helps and good luck fixing!
Could also be that it's encrypted. If thats the case you would need to try to find some dencryption software or research how to bypass the encryption
Felix, this post might solve the problem you're running in to:
Can I replace Ethernet PCB on this External HD?
Be sure to share back with the results.
Good luck!
Felix Bogdanis crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 3,173
